automatic trans difference
Old May 18, 2011 | 08:51 PM
jasenklems's Avatar
Default automatic trans difference
is there a difference between the turbo auto and the non turbo auto trans having some issues with my turbo trans can get a wagon that is a non turbo need to know if there is a difference......
Old May 18, 2011 | 09:11 PM
MattyXXL's Avatar
It will bolt up I think there is just a difference with the torque and gear ratio... But I could be wrong.
Old May 18, 2011 | 09:49 PM
Henry10's Avatar
No-go.
2 issues: A)- 95 and earlier have a different speed sensor B)- Turbo transm has different final drive-ratio (taller) than NA. Your turbo TCM will throw DTC for drive-ratios and limp-home.
Not sure where you are: up here in the North-East used turbo transm are $ 250 at JYs, about the same price for NA. Just get the correct one.
Old May 18, 2011 | 10:39 PM
MattyXXL's Avatar
But if you get the N/A tranny TCM and it is the same year for instance 96 to 96, it should work correct?' just for clarification...
I was told by Lucky @ IPD at one point that it should match up, But like I said I wasnt sure.
but it you want an 96' R trans with 74k there is one on volvo speed auctions....
I was looking to buy it but im putting it off for a little just to save some cash, He still has it. He is asking $250 + shipping.
Here is the link--->Volvo 850R Auto Transmission 74k miles (Item ID: 100502, End Time : N/A) - Performance And Repair Parts For Sale
Old May 19, 2011 | 05:27 AM
Henry10's Avatar
Yes.
T and R share the same transm.
Old May 19, 2011 | 07:23 PM
jasenklems's Avatar
thanks for the info my turbo trans has 300k plus on it and I think that it is time for a new one or would you all think that it would be ok to just do a fluid flush and trans filter kit on it.... I dont really know a lot about volvos but I am trying to learn.....
Old May 19, 2011 | 07:27 PM
Henry10's Avatar
Absolutely. Flush is good, and very helpful in most cases. There is no serviceable transm filter. Check the stickies for procedure on the flush.
Old May 19, 2011 | 07:50 PM
jasenklems's Avatar
mileage is not an issue then if that is the case that is good to know.....
Old May 19, 2011 | 08:32 PM
Henry10's Avatar
These are very durable transmissions. These Aisin transm are part of the AW transm line that are used in Toyota trucks, Tundra, 4Runner, Sequoias, Previa, Supra.
Even my RWD V90 has essentially the same transm, just turned longitudinally.
No transm will outlive abuse though.
Old May 22, 2011 | 09:24 PM
jasenklems's Avatar
well I havent beat on it myself and from what I know of the last owners they didnt beat on it either just a lot of miles and now it is shifting really hard and I would like that to stop I cant afford to rebuild it so I want to keep it alive for a while.....
Old May 22, 2011 | 10:42 PM
MattyXXL's Avatar
Is hard shifting your only problem?
No slipping?
No Shutter?
No kicking out or loss of a gear?
If thats your only issue,
Id do a seafoam trans treatment then after about 25 miles normal stop and go driving do a 3 part flush (Drain and fill drive 25 miles and repeat drain and fill 3x total).
Like I said this is what I would do..
Old May 25, 2011 | 09:22 PM
jasenklems's Avatar
for the most part this is my only issue ( the hard shifting) I have had one other thing happen only twice .... from a standing start floored it didnt want to shift up and bounced off red line like I said it has only happened twice and I know that I am not getting full boost anyway it is a slight problem I dont get the response that I should I think that it is in limp mode for now I have to get the down pipe this friday hopefully it will be the right one will the down pipe from a 96 work on my 94......
Old May 25, 2011 | 09:59 PM
Henry10's Avatar
Too much delay on the upshift is another hydraulic pressure issue. Did you flush the transm yet?
Old May 26, 2011 | 10:21 PM
jasenklems's Avatar
not yet got to wait till payday next friday
mathieu_p
Jan 19, 2013 02:06 PM
ded137t5r
Jun 10, 2012 07:40 PM
sephirothnick
Feb 21, 2008 01:03 PM
ruister
Oct 9, 2006 09:13 PM
opeljunkyard
May 25, 2005 02:27 PM
