Automatic Trans. Fluid Check
Old Oct 5, 2006 | 10:39 AM
ruister's Avatar
Default Automatic Trans. Fluid Check
Cannot seem to find the dipstick or reservoir for transmision fluid on 2001 C70 LPT[:@]
[sm=headbang.gif] Check owners manuel , shows where it should be ,but not there.
Old Oct 5, 2006 | 11:48 PM
Default RE: Automatic Trans. Fluid Check
It is hard to find it is usually hidden by hoses and wires.
Look good around things for a yellow dipstick.
Old Oct 6, 2006 | 09:28 PM
ruister's Avatar
[:@]Still having no luck in finding it!
Could it be sealed?
If[:-]there was a problem with my trainy would the light come on?
Im getting a vibration when I put it reverse?
Old Oct 6, 2006 | 09:45 PM
No it isn't sealed if you can climb under and look for the tube then follow up.
Old Oct 9, 2006 | 09:13 PM
reg's Avatar
reg
I feel your pain! As TECH mentioned it is exactly where your manual shows it...............however................you have to push aside the large hose that covers it. The dip stick has a yellow **** on it. By the way, if you have a 2001 DO NOT LET ANYONE OTHER THAN VOLVO CHANGE THE FLUID. It takes a special fluid that the instant oil places does not carry. There are a zillion postings on this site about the Asin/Warner that is installed on your Volvo.
REG
ORIGINAL: ruister
Could it be sealed?
Granola727
2001-2013 model year XC70
Mar 18, 2015 04:00 AM
ded137t5r
Jun 10, 2012 07:40 PM
volvoQ's
Sep 18, 2010 10:23 PM
nitewitch55
Jul 26, 2006 10:18 PM
WickedPete
Feb 15, 2006 08:43 PM
