AWD 5 speed?
Old Aug 29, 2013 | 12:04 PM
mudpie's Avatar
Default AWD 5 speed?
Did they exist?
I've got a 5 speed trans laying around, and my local wrecking yard has a complete V70 XC. Would the angle gear bolt to the 5 speed?
Thanks
Old Aug 29, 2013 | 01:01 PM
boxpin's Avatar
They exist. If the 5 speed you have is for an AWD then yes. If not, then no. The angle gear is machined to fit into a receiving mated transmission. I believe the manual trans your looking for is a M66
Old Aug 29, 2013 | 01:03 PM
mudpie's Avatar
thanks.
Old Aug 29, 2013 | 01:31 PM
scutyde's Avatar
The manual transmission in the 850 AWD is the M58. The 850 AWD was only available with manual transmission, V70 AWD had both manual M58 and also an automatic transmission AW42AWD.
The angle gear is the same in manual or automatic version has the PN 9181184
Old Aug 29, 2013 | 02:38 PM
boxpin's Avatar
Ignore my post. Listen to scutyde.
Old Aug 29, 2013 | 04:11 PM
mudpie's Avatar
Now I'm confused, though that happens often.
I pulled a 5 speed out of a '95 850 (fwd). Two weeks later the junkyard where I got the transmission put a '98 XC (auto) in the yard. That's what I'm wanting to bolt together.
Old Aug 29, 2013 | 06:34 PM
goldponcho's Avatar
If you want AWD AND a 5-spd manual, you need an M58 from Canada. One half of the transmission case is cast different, with mounting bosses for the bevel gear and a larger opening for the collar that connects trans-BG. Plus, the differential is also different internally. If you've got the money and can handle the fabrication that comes with it, the 6-spd AWD gearbox is the M66.
mathieu_p
Jan 19, 2013 02:06 PM
itr
Nov 22, 2010 07:05 PM
sdc2000
Jun 29, 2009 04:52 AM
GhostRider
Sep 9, 2006 11:30 AM
parrym
Nov 7, 2004 11:30 AM
