AWD brake calipers
Old Aug 4, 2011 | 09:20 PM
mikeawd850's Avatar
Default AWD brake calipers
was wondering if you guys new if any other 850 brake calipers or v70 will fit my 850 awd. or know of any if any are out there high performance brake calipers for my awd?. or i was just going to paint up my oem calipers good idea?
Old Aug 6, 2011 | 05:45 PM
matt01's Avatar
v70 AWD rear calipers are the same.. there is no " performace" caliper that ill bolt right in place..
paint up your OEM ones if they are still working well, and get some ceramic pads (again v70 AWD) and slotted rotors, and you'll probably never have to look at it again intill you spend some time on a track.
Old Aug 7, 2011 | 04:50 AM
mikeawd850's Avatar
Cool thanks I bought some slotted and drilled ones off of ESP with some ceramic pads the calipers are still working well as far as i can tell I bought some caliper paint from crappy tire see how that goes.
Old Aug 7, 2011 | 11:18 AM
matt01's Avatar
1 more thing.. also invest in a steel wire brush for a drill, that'll help you clean up the caliper before paint.. you'll thank me for this one when it takes you 5 mins a caliper!
good luck to you
Old Aug 8, 2011 | 10:54 AM
mikeawd850's Avatar
Ahhh thanks I was just going to use a hand held steel/brass brush
VbuddhaV
Apr 7, 2010 08:01 PM
98_S70_T5_Driver
May 11, 2009 06:33 PM
Heath
May 24, 2008 10:28 PM
funnyguy44444
Dec 9, 2006 10:04 PM
funnyguy44444
Dec 9, 2006 02:17 PM
