Bad noise under the hood.
Old Jul 27, 2012 | 11:17 AM
Stonej's Avatar
Default Bad noise under the hood.
Last night My car starting making this noise and I was hoping someone has experienced this problem or know what could be the cause.
The sound cuts out after 38 sec due to the .mp4 format.
There were no issues before or signs that something was going to happen. The sound is coming from the right side, after looking again it seems more toward the back area right behind the distributor cap. I checked the oil level and it was fine. When it happened I was about a quarter mile away from home, so I drove it back. While driving the noise stayed the same as when idling.
Any advise would be greatly appreciated.
Old Jul 27, 2012 | 12:11 PM
Stripes's Avatar
among other things, it sounds like you have a vacuum leak
also, try taking the distributor cap off, a bit of the rotor may have broken off and could be spinning around in there
Old Jul 27, 2012 | 12:44 PM
slimflex2's Avatar
thats a vacuum leak.might want to make sure none of the hose are broken.check all hoses just to make sure.might also want to check where it is coming from
Old Jul 27, 2012 | 02:05 PM
Stonej's Avatar
Thanks for the comments.
I ended up taking to a shop so I can make it to work. They told me I needed a new starter and possible flywheel if it's damaged. When I went to start it for them it wouldn't crank but you could hear the starter. Rolled the car back and forth in 2nd and then it was able to crank fine. The price on a rebuilt starter was $179, I'm hoping that is the only problem.
Old Jul 27, 2012 | 06:11 PM
Yea, that sounded like a stuck starter to me as well. Metal to metal yuk.
dchludzinski
Jan 28, 2010 05:20 PM
RuslikUA
May 1, 2009 08:01 PM
lsmith
Dec 10, 2007 04:57 PM
lsmith
Dec 8, 2007 04:39 AM
