parking brake
Old Jul 27, 2012 | 02:57 AM
mpower916's Avatar
Default parking brake
how do i tighten the parking brake on my 850 r
it almost doesn't hold at all.
Old Jul 27, 2012 | 10:54 AM
Brick850's Avatar
There is an adjustment **** behind the handbrake handle, pop out the plastic shroud and it is in there somewhere, basically under your centre console bin. Not sure to what spec you need to adjust it to though.
Old Jul 27, 2012 | 07:52 PM
mpower916's Avatar
i got that thing tight on there but the hand brake still is bad any thing else i could do?
Old Jul 27, 2012 | 09:46 PM
Brick850's Avatar
Check for a broken cable, or maybe the cable has stretched beyond further adjustment.
Old Jul 27, 2012 | 11:53 PM
Or pull the rear rotors and see if the parking brake shoe material has fallen off the metal shoes. Mine were so rusty and cruddy the brake material and the pins to hold the shoes in place had gone missing. Figure they fell off from age and moisture and just got chewed up by the spinning rotor. Last picture you can see my shoes had no material left on them.
If the shoes still have their material on them you can back off that screw some at the handle and start taking up some slack using the star wheel at the top of the shoes until you feel a slight drag when you spin the rotor. Once you have the two wheels adjusted you can then fine tune it with the adjuster at the hand lever.
The shoes you can get at Oreilly or autozone but the hardware kit I could only find at FCP.
Attached Thumbnails parking brake-brakes-parking-brake-shoes.jpg   parking brake-brakes-parking-brake-spring-hit.jpg   parking brake-brakes-photo-rear-parking-brake-shoes.jpg
Old Jul 28, 2012 | 03:19 AM
mpower916's Avatar
thanks
TimClifton
Jan 30, 2013 06:11 PM
Johnny Volvo
Jul 12, 2011 11:52 PM
Counselor828
May 18, 2009 09:58 PM
sghokie
Sep 26, 2006 01:35 AM
Mass850
Oct 13, 2005 09:37 PM
