fuel pump will not stop running until I disconnect the battery
Old Nov 3, 2012 | 11:22 AM
amadeo_244's Avatar
Default fuel pump will not stop running until I disconnect the battery
So guys I need help asap I need to fix this before I have to go to work on Monday. So the fuel pump will not stop running until I disconnect the battery. I found this issue because the pump must have been running all night and killed my new battery.
I am going to try to trace the issue right now, but hopefully you guys can think of something too.
Let me know and thanks in advance,
amadeoc_244
Old Nov 3, 2012 | 12:58 PM
Titan Joe's Avatar
It sounds like the main fuel injection relay is welded shut. I'm assuming that this is a 240, and I don't know where it is, but it probably has two relays inside one case. I'd yank it, pull it apart and see if you can see one of the two contacts is not opening. On the 740 the relay always has power available to it regardless of the key switch position. So if it's closed, it will run the pump.
Old Nov 3, 2012 | 03:24 PM
act1292's Avatar
For the 240, the fuel pump relay is behind the glove box. It is usually white, about an inch square and 2-3 inches long, Just remove the felt cover underneath the glove box to access it.
Old Nov 3, 2012 | 05:55 PM
amadeo_244's Avatar
yea it was the fuel pump relay, replaced it and sound stopped.
Thanks guys,
amadeo_244
'86 Volvo 244
bluethunder
Oct 12, 2025 12:02 PM
salazarbuchan
May 16, 2012 06:03 PM
bobb4503
Dec 10, 2011 09:59 AM
dads 740 turbo
Oct 20, 2008 07:43 AM
xjflexer
Mar 26, 2007 08:23 PM
