Best way to remove a stripped Torx?
Welcome to the club
- Grab it with a Vise-grip/locking plier & turn it.
- Use abrasive compound (forgot the exact name)with your current Torx.
- Take a small chisel/flat-blade screwdriver, aim it at the edge of the screw & hit with a hammer CCW.
- If more than 2 screws, remove one & try rotating whatever is being held.
- Spray PB Blaster, take a small flat-blade screwdriver that fits the screw and try rotating it.
If nothing else seems to work, see attached...[8D]
JPN
[IMG]local://upfiles/6892/75131FC13FD14397AE6B8D4B5A992A22.jpg[/IMG]
[IMG]local://upfiles/6892/9C581740DC704A29A81EB26BB722AF9B.jpg[/IMG]
[IMG]local://upfiles/6892/F5FBEBE9EB2B4D2EA405A9E53E7B0BE9.jpg[/IMG]
![Frown](https://volvoforums.com/forum/images/smilies/frown.gif)
JPN
Use a dremel drill or other similar tool with a very small cutting wheel to make a "slot" in it so that you can use a flat-bladed screwdriver. Also, if you can find a way to rig it up during dry time, use an old screwdriver bit and JB Weld, and attach the bit to the screw, let it dry, and twist it out.
