Torx socket to remove door
Old Feb 5, 2013 | 09:02 AM
daver80's Avatar
Default Torx socket to remove door
Need to buy a socket to remove my (deer bashed) door. What torx socket would that be? Dave
Old Feb 5, 2013 | 06:59 PM
goldponcho's Avatar
T40, same size as your thermostat housing bolts.
Old Feb 5, 2013 | 08:24 PM
ibified's Avatar
If you plan on doing ANY work on your car past changing the oil, you'd be better off just buying a set.
Old Feb 7, 2013 | 10:06 AM
daver80's Avatar
Default torx
Well I've got a set of the handled torx drivers, and they come in handy for most stuff up to about 27. When I stopped by NAPA, the torx socket that looked close I think said 4.8 or something. That didnt seem right. Guess now I'll ask specifically about T40.
The lower torx pin on my door looks to be bent and I'm expecting difficulty removing it. Definately a PB soaker. Will that door come off by unbolting the 4 hex bolts that hold the hinge to the front of the door and leaving those pins alone? Dave
allsouthjay
Dec 20, 2010 03:29 PM
MarksS60
Nov 30, 2010 04:55 PM
mercb
Nov 10, 2009 08:15 PM
rmendoza
Nov 6, 2008 08:11 AM
jnduke
Nov 3, 2008 08:55 PM
