biggestrim size 97 850 wagon
Old Apr 23, 2012 | 10:43 PM
mikeawd850's Avatar
Default biggestrim size 97 850 wagon
was looking to put some low profile tires onto my ride was wondering what was the biggest size rim i can put onto my volvo 850 1997 i have only found 19 inch but wanted to talk to you guys first see what you say is 19 the biggest or will it go up higher?
Old Apr 23, 2012 | 11:14 PM
matt01's Avatar
i would say 18" is all you need. You'll have a brutally harsh ride with the 18's and hardly any rubber. If you put 19's I couldnt imagine how bad it would be on an 850/s/v...
Old Apr 24, 2012 | 06:42 AM
gilber33's Avatar
19s? Gross. straight donk.
Old Apr 24, 2012 | 09:41 AM
17" are on the R's. If you go 18's you will have a harsh ride and alway damage tires on bad roads.
Old Apr 24, 2012 | 09:47 AM
mikeawd850's Avatar
ok cool thanks for the info guys i will go with stock tires, if i put 18's on there will i still have a rough ride, with reg sized tires on instead of low profile?
Old Apr 24, 2012 | 10:13 AM
MattyXXL's Avatar
Lift that bit*h and throw 26"'s under it...
THAT WAS A JOKE BY THE WAY!!
All you need is 17's lowers a little, and spaced...
Old Apr 24, 2012 | 10:18 AM
The issue with what will fit is not the wheel size but the overall size of the wheel/tire once mounted. Stock tires are likely 195/65-15's or 205/55-16's. The R's have 205/45-17's but most of us run 215/45-17's. No matter how you stack them, they are all the same circomfrence. So they stand 32" off the ground, from ground to top of the tire (not the size, just an example). If you get 18" wheels and put 225/55's on them the wheel/tire will be larger and will rub in your wheel skirts or finders.
We are not telling you not to get larger wheels and run low profile tires, we are telling you what fits best. 17" wheels will look low, people compliment me on mine almost daily. If you go 18's and put 225/45's on them you will have some rubbing issues. 215/35's may be a better fit but will likely get damaged a lot.
On my sedan, I was running Kuhmo Estas and damaged those tires all the time. I never ran any of them out, had to replace them from damage all the time. If you have deep pockets, toss low profiles on.
Old Apr 24, 2012 | 11:09 PM
mikeawd850's Avatar
lol i was in seattle a couple weeks agoand saw a caddy raised with 24's so it is an option
thanks for the info once again guys
Old Apr 25, 2012 | 05:06 PM
DrewsT5's Avatar
My car's PO had 18" rims installed on it. You can see what it looks like if you click on link that'll take you to the pic in my "Garage." I don't have any rubbing but the ride is definitely harsh. I am looking to eventually replace them with 17" R rims. It should feel better with a little more rubber in the tire walls. I concur with what everyone else is saying. 19" rims would look out of scale and perform poorly; 18" will fit and look good; 17" seem to be the best in looks and performance.
Old Apr 29, 2012 | 02:12 PM
volvoguy23's Avatar
YO I GOT ME SOME 26'S ON MY BRICK AND IT RIDE PIMP HOMIE YALL SHOULD DO IT TO!!!!!! LMAO. Just use 18s because those are considered big on the 850 with my stock turbo wheels the ride is rough already!!!
journeyforce
Sep 2, 2021 12:31 AM
bond007
Apr 6, 2011 01:56 PM
tomservo
Jan 3, 2008 05:18 PM
megatrack
Sep 27, 2007 05:04 PM
TLC_Lover
Aug 11, 2007 09:44 PM
