Blue smoke when warm
Old Jun 15, 2007 | 11:02 PM
sparkmaster1's Avatar
Default Blue smoke when warm
I have a '94 850 turbo wagon that puts out a decent puff of blue smoke after it idles for a while when it's warm. Other than that it runs clean. Any ideas? Thanks, Tim
Old Jun 15, 2007 | 11:24 PM
RedTurbo850's Avatar
Default RE: Blue smoke when warm
A puff or a lot?
Blue smoke = EngineOil
Old Jun 15, 2007 | 11:41 PM
Just a puff... You can see it in the review mirror. It's just when you take off.[/align]
Old Jun 16, 2007 | 06:45 AM
Vent system could be clogged or the turbo might be going bad.
Old Jun 16, 2007 | 08:24 AM
Any tips on how to clean the vent system? I just bought the car and I don't have a manual yet. Thanks for the reply. Tim
Old Jun 16, 2007 | 08:35 AM
Best thing to do would be to replace the vent box and all hoses.
It has probably never been done.
Old Jun 16, 2007 | 08:58 AM
What's the mileage?
Tech, by vent system, you mean the PCV right?
Old Jun 16, 2007 | 09:04 AM
It has 170k. I'll check with IPD and see if they have the parts. I'm a Air-Cooled VW guy so these watercooled things are a bit "new" to me. Thanks, Tim
Old Jun 16, 2007 | 09:10 AM
FCP Groton would be the easiest place to look since they carry a huge selection of OEM parts, but if you check the sticky, I'm sure you could do some price shopping..
IPD is expensive...
Old Jun 16, 2007 | 09:13 AM
http://www.ipdusa.com/Volvo-850/Engi...p-72-153-1894/
I'm thinking this is it.
Do you need to remove the intake manifold to get to it?
Thanks for all the advice. Tim
Old Jun 16, 2007 | 10:17 AM
This is the one from FCP...Seems like there is more parts to it...
http://www.fcpgroton.com/volvo850oiltrapturbo.htm
From my understanding, you don't need to remove the IM.
Old Jun 17, 2007 | 07:09 AM
On the 850 Yes you will need to remove the intake to replace everything.
Old Jul 28, 2007 | 10:25 PM
Update!!
I replaced the whole PCV system with new parts and I still have the smoke.....
When it's idiling I have smoke out the dipstick tube (with the stick removed) and out out of the fill cap.
This car has 170k on it... I guess I need to do a leakdown test and see what I come up with....
Any other suggestions?? Thanks, Tim
Old Jul 28, 2007 | 10:44 PM
Start with a leakdown test and a compression test (Dry then wet)
Old Jul 30, 2007 | 04:05 PM
sevorges's Avatar
I have the same car & problem. The problem is excessive crankcase pressure, which is sucked into the intake through the oil seperator (PCV system). I have replaced this, and all hoses often. The other problem is that oil seeps out through the dipstick and fill port. This has run accross the engine and the passenger side front brakes. I have found no official correction from various sources. The most credible explanation thus far is bad exhaust valve seals, causing the excessive crankcase pressure..... I plan to perform a valve job once my better-half allows me a couple weeks of down time for the car...Also need to replace the evaporator.
Old Jul 30, 2007 | 05:57 PM
JimKW's Avatar
Here is the kit that is sold by fcpgroton for $135. I didn't add the prices up for the ipd items you posted. I liked just buying the kit. Yes you do have to take off the intake manifold.
http://www.fcpgroton.com/volvo850oiltrapturbo.htm#early
Old Jul 31, 2007 | 04:14 AM
  #17
JPN's Avatar
JPN
...and if you plan to do the job by yourself, be sure to order intake manifold gasket as well.
JPN
Squirt
Dec 29, 2020 02:53 PM
cvearer
Sep 4, 2014 10:26 AM
Blue91SL
Aug 15, 2014 08:34 PM
vwvolvo04
Jul 12, 2010 02:11 PM
phils94850
Mar 18, 2007 11:25 AM
