Brake noise/ vibration and tire question
Old Apr 12, 2011 | 07:38 AM
need 4 speed's Avatar
Default Brake noise/ vibration and tire question
I own a 97 850 GLT and have just replaced the front rotors. Everytime I apply the brakes, there is this intense vibration that shakes the whole car which is accompanied by a loud moaning sound as it comes to a stop. The noise has happened before after lightly sanding the rotors and pads last year in an attempt to eliminate that brake squeal. My next question regarding tires on a lower car. I installed lowering springs and was wondering if going with 205's would rub the wheel well since the car is lowered? Thanks for your help.
Old Apr 12, 2011 | 01:26 PM
ibified's Avatar
205s will probably not rub, depending on how low you have gone. just make sure you stick with a 50 series tire. "205" is the section width, and the "50" is the height of the tire.
if you're getting a vibration when you stop, and it just appeared after doing the front brakes, you probably got a rotor (or both) that are warped. Either have them turned or take them back and exchange them. You should NOT have that happening.
Old Apr 13, 2011 | 07:44 PM
TonyS's Avatar
Further question on this — I also had a vibration upon braking from the driver side front tire. I changed the pads, got new rotors. I like to think it vibrates slightly less, but I wouldn't bet on it. Made me wonder if I should have replaced the caliper at the same time, since some of what I assume was once rubberized coating over the caliper piston was worn. Could that contribute to vibration? Is there anything else to consider?
Old Apr 13, 2011 | 08:53 PM
ibified's Avatar
caliper will not cause pulsation on braking. I'd check tie rod ends or ball joints.
ocean238
Apr 17, 2008 06:20 PM
ingle24
Oct 13, 2006 07:54 PM
YUKON
Sep 22, 2006 08:40 PM
daisydaisy
Jan 26, 2006 11:52 PM
