brakes and squeals
Old May 11, 2010 | 06:44 AM
vpatrol's Avatar
Default brakes and squeals
okay I have banshee type brakes that puts finger nails on chalkboards to shame. I know other threads have talked about oem being the way to go but does anyone know why after market causes squealing brakes? My pads are pretty new however the rotors have some corrosion around the edges where the pads generally don't make contact. I'm assuming that corrosion creeping towads the pads is causing the sound. OEM is expensive here so would aftermarket rotors eventually squeal too? Or is it the pads that normallly contribute to squeally volvo brakes?
Cheers
Old May 11, 2010 | 02:42 PM
In most , not all but most cases brake noise is caused by poor installation. I don't think you need OEM pads as Bendix, Wagner ... etc stay in business only as long as they make a product that works and works quietly. Yes there are "hard" pads out there that will make noise no matter how well you clean and lube everything you can but if you only replace the pads without turning or replacing the rotors the odds are they will squeak. Quality pads of some brand name with new properly cleaned rotors or your old rotors properly turned so the surfaces are clean and flat normally will yield excellent results. I do a lot of brake jobs and what I usually end up fixing for someone who just did "a complete brake job" is remove scale, clean and then lubricate the areas where the calipers slide on the mounts and where the pads slide in the calipers. Then there are the backyard guys who just slap pads in, no cleaning, no lube and don't bother to have the grooves machined out of their rotors or replace them. It's going to make noise. That's why you paid more for the twelve pack of beer than the whole brake job cost.
The twelve pack comment isn't aimed at you as much as my frustration with customers who want the cheapest job they can get when they are for the most part driving nice cars. That and the thought the ten or fifteen bucks they saved buying cheap pads may make the difference between stopping just before then hit someone or something and finally stopping on top of someone or plowed into something.
You may have some excessively worn calipers or something else going on but you might want to take the effort to go through it again to make sure nothing was missed before you buy new pads. I'd remove that ridge of rust as anything that doesn't let the pad run flat against the caliper is a safety issue and could also be the cause of noise or some slight pulsing in the pedal.
Old May 11, 2010 | 03:18 PM
JimKW's Avatar
I can't really answer your quesiton as to why, but I use OEM pads and Brembo rotors. I don't find them to be much more expensive than any other better quality pads and rotors. I usually order them from fcpgroton, but in a pinch I just buy them at the dealer in which case I use OEM rotors also. I have tried other pads and took them off after less than 5K miles because of squealing. I would rather spend a little more than hear that sound.
$55 for OEM pads:
https://www.volvoparts.com/index.asp
Same thing fcpgroton for $65:
http://www.fcpgroton.com/product-exe...category_id/52
Old May 11, 2010 | 04:24 PM
vpatrol's Avatar
Originally Posted by JimKW
Those prices are great except the shipping to NZ makes them a tad more expensive
Old May 11, 2010 | 04:45 PM
JimKW's Avatar
Sorry about that. Didn't notice your location. Pay my way and I will bring you a set. haha
Old May 11, 2010 | 07:42 PM
vpatrol's Avatar
only if you help me rebuild an overheated motor on an 850 turbo wagon with 5spd manual that I want to buy. Auction currently at about $200usd. Here's hoping!
MKH
Jun 5, 2013 01:27 PM
screamer
Jun 6, 2012 04:43 AM
nathswansea
May 21, 2012 06:23 AM
bluenote76
Sep 4, 2011 10:46 PM
JonesyGT
Sep 17, 2005 03:41 PM
