Rear Brakes and HELLO!!!
Old Sep 16, 2005 | 11:40 AM
JonesyGT's Avatar
Default Rear Brakes and HELLO!!!
Hello this is my first post on this forum so i would like to introduce myself, I live in Bolton, Uk and drive a renault clio 172, my dad owns a 850 t5 and its a cracking car with a problem........ the rear discs are shot to bits and are in need of replacement, are the rear wheel bearings integral to the discs? i want to change them in one hit if i can rather than messing around with bearings at a later date.
Cheers for the help and Hello again!!!
Old Sep 16, 2005 | 08:46 PM
Default RE: Rear Brakes and HELLO!!!
The bearings and rotors are 2 seperate peices.
Old Sep 16, 2005 | 10:33 PM
JonesyGT's Avatar
do the bearings press into the rotor and then mount onto a stub axle or are they part of a seperate hub?
Old Sep 16, 2005 | 11:12 PM
reg's Avatar
reg
As soon as you pull the caliper off (two bolts) you can simply pull off the rotor, change it, change the pads in the caliper and put it back the same as it came off. I should take you 15 to 20 minutes once you have your wheel off.
R.
Old Sep 17, 2005 | 11:45 AM
Once you remove the caliper you will need to remove one 10mm screw and the rotor will come off.
The hub and the bearing are one peice.
Old Sep 17, 2005 | 03:41 PM
JonesyGT's Avatar
Lovely cheers chaps!!!
Scuba Jim
North East
May 26, 2024 11:29 AM
pampers4u
Mar 10, 2013 10:10 PM
grndslm
Jun 30, 2012 02:44 AM
jcmartin
Feb 27, 2006 10:58 AM
JimKW
Jul 4, 2005 12:19 PM
