Bulb Wattage
Old Jan 31, 2007 | 12:44 PM
B1mmer's Avatar
Default Bulb Wattage
After doing an inquiry, I realized the illumination bulb in my rear defroster switch should be lighting up. When I activate it, the amber light comes on, but the illumination bulb is toast. I pulled the switch last night and took it apart. I removed the soldered in bulb for illumination. Does anyone know the wattage of the bulb? I plan to head to Radio Shack and buy another bulb and solder it in, but I don't want to get one that is too bright. I would guess it's between 1.5 and 3 watts. Any ideas? - AB
Old Jan 31, 2007 | 12:56 PM
JPN's Avatar
JPN
Default RE: Bulb Wattage
Hi AB,
I think the wattage for the bulb is less than 1W. I used a bulb I found at Radio Shack, the only one that could physically fit. It is 12V & 60mA, so the wattage is:
12 x .06 = 0.72W.
This bulb is brighter than the original, and other than the dealer I am not surewhere you can find the exact match (and the dealer probably wants $10 for one[8D]).
Someone noted that the bulb can be installed without soldering, though I could not quite understand the procedure. Either way would work, I believe (I soldered mine).
Good day,
JPN
Old Jan 31, 2007 | 01:15 PM
B1mmer's Avatar
Tks JPN. I'll go your route as well. A little brighter for $.25 is worth it to me - AB
davej
Apr 22, 2011 08:47 AM
2005s60
Jan 19, 2011 01:50 PM
rsylvester07
Aug 12, 2010 12:12 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
jdbs3
Nov 16, 2004 11:42 PM
