A/C compressor always on
Old Jul 8, 2008 | 08:02 PM
DOHCRT's Avatar
Default A/C compressor always on
I just bought a '96 850 T5, and noticed that the A/C compressor is on at all times. The car is equipped with electronic climate control. I pulled the A/C relay out but the compressor clutch still engages any time the ignition is on, even if the engine is not running. Any ideas on how to find the problem?
Old Jul 8, 2008 | 08:12 PM
Default RE: A/C compressor always on
Does someone have it direct wired with another relay?
Old Jul 8, 2008 | 08:28 PM
DOHCRT's Avatar
I looked for any hacked-up wiring, but I didn't notice anything. Anywhere in particular I should look? The A/C relay seems to function normal. When the A/C switch on the ECC is turned to "AUTO", the relay clicks.
I hooked up the Volvo System Tester, and in the data stream the A/C relay is always "on" even if the switch on the ECC is in the off position. There are seven DTC's stored in the ECC, but they are all for damper motor operation and interior temp sensors.
Old Jul 8, 2008 | 08:35 PM
Is the ECC set to defrost?
If so that may be why.
If not then the ECC module might be bad.
Old Jul 8, 2008 | 11:24 PM
DOHCRT's Avatar
It stays on no matter what mode is selected. I think Im going to take apart some of the dash and look through the wiring. I hope there is nothing wrong with the ECC module, those are expensive!
Old Jul 9, 2008 | 08:46 AM
Psaboic's Avatar
Sounds like you are on the right track. I'm betting on wiring or a bad ECC. HOpefully it is a simple wiring issue. Good luck!
Old Jul 10, 2008 | 05:45 PM
DOHCRT's Avatar
I figured it out. There were two wires under the dash going to the A/C relay that were melted together. This consequently bypassed the relay and would engage the A/C clutch anytime the ignition was in position 1 or 2. The previous owner had the evaporator and compressor replaced, so I think the melted wires could have been related to the compressor failure. Everything works great now, and the car is faster now that the compressor shuts off at full throttle.
Old Jul 10, 2008 | 06:03 PM
Quick Brick's Avatar
ORIGINAL: DOHCRT
I figured it out
SWEET [sm=signs007.gif]
Old Jul 11, 2008 | 09:11 AM
HummerGuy's Avatar
Good job troubleshooting!
Old Jul 12, 2008 | 07:12 AM
Glad you found the problem.
Old Jul 17, 2008 | 07:29 PM
Volgrrr's Avatar
ORIGINAL: DOHCRT
Yipee!
I have finally found a person who cannot switch their A/C off.
I have the same problems though I am sure the cause is different. I cannot isolate a 12v supply that appears on both sides (should be only one side) of the low pressure switch connector after the electrical connector is removed from the pressure switch.
Therefore, I am getting ready to change the ECC to see if that is the problem - and I will have my fingers tightly crossed that a faulty ECC is the problem.
Old Jul 17, 2008 | 07:39 PM
I will keep my fingers crossed for you.
Old Jul 19, 2008 | 12:39 AM
Volgrrr's Avatar
Thanks Tech,
Much appreciated.
m4gician
Oct 17, 2008 03:45 AM
mgimza
Nov 14, 2006 09:11 PM
AaronD81
Jun 2, 2006 08:39 PM
tennisguy
May 18, 2006 07:32 PM
barge
May 12, 2006 10:55 PM
