A/C Compressor Clutch Reshimming
To be honest, trying various nylon items until you get the right gap seems like more work, and is less reliable, than pulling the clutch off and removing shims. Just measure the gap before you pull the clutch, measure the shims inside there and remove till you know you'll be back to .2mm - .5mm. Bolt it back together. It might take you an hour.
I have a 2006 that is acting up the ac blows cold until the throttle is raised and then it's all over for the cold air. can my pulley be shimmed in this fashion? It seems that all of these posts are referencing older models
