cant change gears
Old Oct 26, 2007 | 08:21 AM
glt93's Avatar
Default cant change gears
I have a manual and I was driving down 141 and i was at a light i started out in first then I went to shift and it wouldnt let me I had the clutch down and it still wouldnt let me change gears
Old Oct 26, 2007 | 07:18 PM
Default RE: cant change gears
Maybe the clutch went out.
Do you still have brakes?
The clutch and brakes share the same fluid.
Old Oct 26, 2007 | 09:50 PM
glt93's Avatar
I have brakes and the fuild is still at the full level I think it is the slave cylinder or the hose from the slave cylinder to the clutch cylinder
[/align]
Old Oct 26, 2007 | 11:44 PM
Sounds about right if you still have fluid.
Maybe try bleeding it.
Old Oct 27, 2007 | 10:12 AM
glt93's Avatar
Is the slave cylinder in the bell housing
[/align]
Old Oct 27, 2007 | 10:24 AM
I believe it is.
You can change most of the parts without removing the transmission.
Old Oct 27, 2007 | 10:32 PM
glt93's Avatar
Tired to bleed the slave cylinder and now the clutch pedal is all the way down to the floor and it wont return to the normal position I have no clue
Old Oct 28, 2007 | 08:45 AM
Did you try bleeding it like you would the brakes?
Old Oct 28, 2007 | 09:11 AM
glt93's Avatar
Yup I had some one pump the clutch and it fluid came out then the fluid stopped then the more came out then I close the bleeder screw then I press the clutch in it stayed to the bottom of the floor
[/align]
Old Oct 28, 2007 | 09:45 AM
Try pumping the pedal up some even if you have to lift it.
Then after pumping it about 5-10 times hold it down them open the bleeder.
Then try again and see if the pedal comes back.
Old Oct 28, 2007 | 09:48 AM
glt93's Avatar
I did that yesterday I pump the pedal at least 15 or 16 times and then I open the bleeder screw and no fluid came out
[/align]
Old Oct 28, 2007 | 09:52 AM
glt93's Avatar
Actually the arm that is connected to the slave cylinder is stuck in the open position the arm
[/align]
Old Oct 28, 2007 | 09:53 AM
Were you doing this by your self?
Old Oct 28, 2007 | 04:10 PM
glt93's Avatar
no I had a friend
[/align]
Old Oct 28, 2007 | 08:09 PM
Oh ok just making sure then something must have failed all together.
Old Oct 31, 2007 | 07:41 AM
glt93's Avatar
its my clutch it burned out do you know how long it would take to change it
Old Oct 31, 2007 | 12:10 PM
  #17
csx3691989's Avatar
It took my son and I a day and a half to change the clutch. I do have an engine hoist which made it easier. We used a jack under the engine and use the hoist to holt the transmission. I don't know why a burned clutch would not release. Maybe the fork has sliped put of position or the throwout bearing is bad. I assume from your previous posts it's not the slave or master cylinder.
Old Nov 1, 2007 | 06:17 PM
  #18
I would say the same about 1 day and a half in a Home enviroment.
82dizzler
Feb 14, 2011 09:28 PM
itsamac
Apr 10, 2007 12:45 PM
cage911
Jan 18, 2007 09:42 PM
tupapison
May 13, 2006 04:30 PM
biopower
Aug 18, 2005 09:42 AM
