Can't figure out how to make new trip computer work
Old Oct 27, 2010 | 09:34 PM
mmajarian's Avatar
Default Can't figure out how to make new trip computer work
I have a 1994 850 (the older version with no sunroof). Bought a trip computer on eBay that was advertised as matching my car - when I received it, the plug was the right shape (the flat gray one) and all seemed to go well with the install. However, when I try to use it, the display stays blank except for the clock. I know that the LCD works, because all of the components light up briefly when I turn the car on. But I don't get "DISC" or any other message when the car is running; only the clock.
Anyone have any idea as to what could be wrong? I tried disconnecting the INFO switch just to see if it would give me an error, but that didn't change anything. I don't have the ambient temperature sensor installed, but I hesitate to spend more for parts if this won't work anyway. At this point, I'm stuck - from what I can tell, the 850s didn't need extra programming, and the plugs matched my cluster and obviously are powering at least the clock.
Any ideas? They'd be appreciated. Thanks in advance.
Edit: if it helps, I've attached some pictures - of the cluster before I installed the new computer, and of the computer itself.
Old Oct 27, 2010 | 09:51 PM
It should work unless it does not 100% match. I know there is many different setups.
There is even a few posts on the forum about the different ones.
Old Oct 27, 2010 | 10:05 PM
gilber33's Avatar
You have a Yazaki cluster, I doubt that trip is going to work in that cluster. I'm guessing that trip will only work in the more common cluster, I forget the name, but it's the one that basically every 850 has.
Old Oct 27, 2010 | 10:53 PM
mmajarian's Avatar
VDO is the other one. I thought that I had done enough research going into this, but the thing of it is - I can't figure out why the plug would fit, and the clock would work, if it was designed for another cluster. Are there VDO clusters with the thin gray connector? I thought that the thick green one was the only one that worked with them.
I found another thread in the forum where a guy replaced his cluster (and computer) with a VDO one and it worked fine - but honestly, I like the way mine looks a lot better, and a new one wouldn't be worth the price. Do you know if any 1994s came with a different Yakazi cluster? Or did they only ever make one?
Old Oct 28, 2010 | 12:13 AM
ibified's Avatar
I have an extra VDO cluster in my parts bin. PM me if interested. You didnt specify if it's a turbo or not, but the gauge i have is out of a 1994 Turbo, and it's a VDO.
**edit: everything works on this cluster except the odometer. with the cluster out, its $25 for the gear and it's MAYBE 30 minutes to do it. There may be a couple burned out bulbs, but again, it's an easy fix with the upper dash out - just plug in and turn on and see which ones dont light. Personally, I replaced ALL the bulbs in my gauge when I replaced it. I'd hate to do it only to have to tear it down for a bad bulb a month later.
Old Oct 28, 2010 | 01:00 AM
mmajarian's Avatar
Hey! Appreciate it, but mine is a non-turbo. The price you have to pay to drive a stick, I guess. Thanks though.
Old Oct 28, 2010 | 06:33 AM
gilber33's Avatar
I think it's just Yazaki or VDO. I've never heard of different variations of them, and I would have seeing how many clusters go in and out of VS for sale.
That's a pretty hefty price you have to pay. I think I'm going to stick to my turbo/stick combination.
Old Oct 28, 2010 | 01:31 PM
mmajarian's Avatar
I'm jealous- wish I had the turbo. Anyway, maybe this just won't work. Thanks, all.
Old Nov 6, 2010 | 08:11 PM
JPN's Avatar
JPN
FYR. If the car has necessary wiring, you may want to look at the connector on both the LCD & car side to see if the number of the wires match.
P.S: Thw attached image has been reduced to less than half so the legends are illegible. The attachment size needs to be increased.....
JPN
Attached Thumbnails Can't figure out how to make new trip computer work-850-inst-6-.jpg
deeppaul
Dec 30, 2009 08:46 PM
TiggerBBSim
Apr 3, 2009 12:17 PM
tarun90
Dec 30, 2007 10:32 AM
jorhyne
Oct 20, 2007 06:31 PM
bigdaddyrdpjr
Sep 9, 2007 10:30 PM
