Weird engine hesitation problem...dealer can' figure out why
Old Dec 27, 2007 | 11:00 AM
tarun90's Avatar
Default Weird engine hesitation problem...dealer can' figure out why
Ok, last December, my dad bought a 2000 Volvo S80 with about 46k miles on it from Sewell. Originally, it was great, but had to have quite a bit of work done on it (software had to be reinstalled, some major suspension work (2k+) and then it ran really smooth). Now, there's been a problem recently. It doesn't happen all the time, but when you accelerate, it appears as if the engine is "hesitating" and it doesn't give that acceleration...then like 10 seconds later, the acceleration comes up and the RPMs rev up. It's hard to explain through here, I'm not sure if any of you have experienced it? The dealers have run all the diagnostic systems and their computer systems are not showing any issues...but when they drove it, they could feel it. So, they did some software update and the frequency of the problem has gone down but it still exists. Does anyone know what I'm talking about? It's hard to explain unless you actually drive it. It's like the acceleration is delayed and then comes up later. Is it serious? Engine issue?
Old Dec 27, 2007 | 06:06 PM
Default RE: Weird engine hesitation problem...dealer can' figure out why
Turbo or NON?
Old Dec 27, 2007 | 10:47 PM
tarun90's Avatar
It's a 2.9 non turbo.
Old Dec 28, 2007 | 09:50 PM
I would say maybe a bad throttle body.
Old Dec 29, 2007 | 11:02 AM
tarun90's Avatar
Well, at the dealer, when they are running all the diagnostics, nothing is showing up. What exactly is a throttle body?
Old Dec 29, 2007 | 12:06 PM
That is what makes the engine rev.
Your car is fully electronic. The throttle bodys on your car are known to go bad all the time.
Old Dec 30, 2007 | 10:17 AM
tarun90's Avatar
So would you say this is a serious issue? I mean this "hesitation" only happens sometimes...
Also, you're saying that the throttle body's on 2000 S80's are known to go bad?
Old Dec 30, 2007 | 10:32 AM
From 1999-2002/2003 are known to go bad.
So much that here in the states there is an extended warranty on it from the Dealer.
The warranty is 10 years 200,000 miles.
deeppaul
Dec 30, 2009 08:46 PM
TiggerBBSim
Apr 3, 2009 12:17 PM
jorhyne
Oct 20, 2007 06:31 PM
bigdaddyrdpjr
Sep 9, 2007 10:30 PM
