Can't Read The Codes (red light doesn't blink)
Old Aug 6, 2006 | 04:03 PM
mwr's Avatar
mwr
Default Can't Read The Codes (red light doesn't blink)
1994 850 Turbo Wagon. I tried to check the diagnostic codes this morning to start to troubleshoot the SRS light displaying (posted in another thread), but the red light that's supposed to flash the codes doesn't flash at all. Here's what I did:
- Turned the ignition on (position II).
- Put the jumper wire from A into A2, then pressed the black button for one second. Result: no red light.
- Same as above with jumper into B5. No red light.
I sucessfully read the codes some time ago, but not this morning. I'm hoping I skipped doing something I need to do.
Old Aug 6, 2006 | 07:42 PM
billofdurham's Avatar
Default RE: Can't Read The Codes (red light doesn't blink)
The instructions I have say to plug flylead into the module then switch on the ignition. This may be why you are not reading codes.
Old Aug 6, 2006 | 10:48 PM
mwr's Avatar
mwr
ORIGINAL: billofdurham
Thanks, but I also have those instructions and did it that way first. I did it both ways and neither worked.
Old Aug 7, 2006 | 05:40 AM
code33's Avatar
Try firmly pushing for 2-3 seconds.
Old Aug 7, 2006 | 03:32 PM
Having re-read my instructions, which are split for the various components, some say to push for 5 seconds.
Frans562
Mar 10, 2013 11:55 PM
chimmychong
Apr 2, 2008 08:34 AM
1999S80T6
Mar 12, 2008 08:10 PM
Emerald S80
Dec 4, 2005 01:48 AM
Sssnake
Jul 18, 2005 03:37 AM
