car cranking but not starting
Old Oct 19, 2012 | 04:39 PM
lemon drop's Avatar
Default car cranking but not starting
1996 volvo 850 turbo.i have tried everything i can think of. The horn works so i know its not the battery. ive replaced the cap, rotor, and the ignition control modual. also i check to see if the fuel pump was priming up and it did.ive tried cleaning the cam sensor to see if that was the problem. and lastly i noticed that there was no spark at all anywhere. I am definitely stumped on this on. help pleeease :P
Old Oct 19, 2012 | 10:12 PM
Ignition coil.
Old Oct 20, 2012 | 12:10 AM
Rafaellon's Avatar
Well, it is looking really puzzled one as the most things that are the factors behind the problem have been change, hmm.. what about the radiator and coolant level ?
Old Oct 20, 2012 | 08:29 AM
Psaboic's Avatar
+2 on ignition coil and or the wiring at the coil
Old Oct 20, 2012 | 02:11 PM
The ignition system needs a minimum of around 10.6 volts to work properly. That isn't the exact number for a Volvo but it's an average to look for when the engine is cranking. With the starter engaged you need to have at least 10.6 volts available for the ignition system and ECU to function properly.
When you say you replaced the ignition control module did you do it as the stock coil & module assembly thereby getting a new coil also ??
The horn will operate at a voltage way below 10.6 so the horn working doesn't tell anyone anything other than the battery isn't totally dead. You need to test the voltage with the starter turning the engine over.
If you tested for spark at the coil and found none then doing the cap and rotor wouldn't have done any good as they are downstream of the coil. If the coil isn't producing a spark the cap, rotor and wires wouldn't affect spark production.
Old Oct 20, 2012 | 05:20 PM
When I had a bad battery, on the volts were at 11.3, cranking the volts would drop to 7.8. It started every time. Just my experience.
Old Oct 21, 2012 | 01:02 AM
I have to be careful about working off memory. The standard is 9.6 while cranking and yes it can drop lower and still keep running. I tried to find a figure for shut off for an electronic ignition but couldn't.
As for a no start issue I would stick with the 9.6 volts or more. If you don't read that then you have an issue to repair before going further.
thehacker44
Mar 9, 2012 08:23 PM
the.weave
Jan 12, 2012 11:14 AM
Riculus
Nov 7, 2009 12:01 PM
T4
Nov 5, 2008 11:24 AM
Natalie
Jan 14, 2006 11:53 PM
