Car door will not open!
Old Dec 30, 2014 | 12:43 PM
Volvos14's Avatar
Default Car door will not open!
The passenger side car door will not open from the inside. Will open from the outside. Any suggestions on how to fix? With out pay $200+. Thanks in advance...
Old Dec 30, 2014 | 12:46 PM
firebirdparts's Avatar
Take the door panel off and look in there and see how it's made. The linkage between the inside door handle and the latch may be disconnected, but you look and see.
Old Jan 6, 2015 | 10:20 PM
It's a shaky video but gives you an idea of getting the panel off.
Old Jan 16, 2015 | 09:53 AM
Galaxy850Sunny's Avatar
I have this issue before. The most likely culprit, which I definitely experience is that the their is a metal bracket with 2 hooks on it with little rubber holding piece on both hooks. This little bracket goes into the door acutuator that connects the opening mechanism to the inside door **** latch. These little rubber piece over time of wear and age fall apart and does not hold the bracket to do its job. I had to do 2 doors like this on my 850.
lleibeck
Apr 21, 2012 01:55 PM
James66666698
Sep 6, 2010 04:29 PM
klod622
Jan 31, 2010 06:11 PM
guptash
Nov 25, 2008 09:39 PM
