Car running cold at highway speeds
my 95 850na has always ran regularly, with the temp just barely above the horizantal point. but recently with the cold weather (reads 0c, at highway speeds drops sometimes), my temp reading drops significantly when cruising at highway speeds. the heat also stops heating.
Im just wondering if this indicates an issue with the temp sensor, or thermostat, or both?
Does it still run colder at highway speeds after you've replaced the t-stat?
XC9O
11-01-2016 11:44 AM
