volvo 850 stearing hard to turn
Old Jun 18, 2010 | 02:42 PM
chadman551's Avatar
Default volvo 850 stearing hard to turn
Just the other day, i went to drive my 1995 volvo 850 and the stearing seemed to be really hard almost like i had no power stearing, on the drivers side, there is a bunch of grease on the front subframe and i wasnt sure what it was from i couldnt see and rips in any boots and i cant figure out what is wrong with the stearing. thanks
Old Jun 18, 2010 | 03:16 PM
vjaneczko's Avatar
Two easy things to check; power steering fluid and the serp. belt. Do they look OK?
Old Jun 19, 2010 | 09:03 PM
chadman551's Avatar
Yes they are both fine i put a new belt on recently and the fluid is at the right level
Old Jun 19, 2010 | 09:43 PM
chadman551's Avatar
im wondering if its is possibly the Power Steering pump but i cant tell
Old Jun 20, 2010 | 03:30 PM
vjaneczko's Avatar
Lots of people say that the steering pump is a rock-solid device, but it may be shot – dunno how to test it, though.
Did the problem occur immediately after you changed the serp. belt?
Old Jun 20, 2010 | 06:17 PM
Bobec's Avatar
If it's the pump here you go
http://www.pskits.com/catalog/-c-61_96.html
Mine was leaking and I bought this kit and rebuilt the pump. You have to have a pulley puller, not a gear puller, auto zone has it as a free loaner. Pay very close attention to how it comes apart. The vanes have to go in the same way and the pump rotor is has to be aligned just right on the roll pin and inlet and discharge ports. I used lucas PS pump fluid and it is soooo quiet even when I hit the stops.
Old Jun 20, 2010 | 10:01 PM
chadman551's Avatar
I replaced the power steering pump and it did not change anything the steering is still hard and i was wondering if it may need greased or something like that, it is still the same and is really hard to turn, can anyone help me out?
Old Dec 31, 2010 | 12:54 PM
mdblythe's Avatar
My Dad's 850 is doing the same thing, I'm about to go pull a pump but after reading this, that may not help. were you able to figure out what was wrong with your power steering?
chadman551
Jun 22, 2010 08:49 PM
chadman551
Jun 19, 2010 09:16 PM
Transx
Mar 7, 2010 08:16 AM
dbheatherly
Nov 27, 2007 06:24 PM
jbuelow
May 22, 2007 12:01 AM
