carbon buildup removal
Old Mar 12, 2007 | 05:00 PM
M850's Avatar
Default carbon buildup removal
95 850 has carbon buildup want to know if anyone has used Top Engine Cleaner (TEC) before?
Thanks Mark
Old Mar 12, 2007 | 05:54 PM
S70driver's Avatar
Default RE: carbon buildup removal
Try SeaFoam
Old Mar 13, 2007 | 03:26 PM
bitter356's Avatar
BP has a multi-part TEC kit. You can pick it up at your higher end parts stores, or foreign only stores.
Good luck.
Old Mar 13, 2007 | 03:29 PM
zmontgomery's Avatar
I used to use Sea Foam on my Toyota landcruiser (205,xxx miles). I'd pour half the can in through the carb while the truck was running, and then put the other half in my gas tank. It worked well.
Old Mar 14, 2007 | 12:09 PM
JPN's Avatar
JPN
Hello Mark,
Greetings from Yokohama.
Besides SeaFoam, I would use Techron fuel system cleaner in the tank, and use throttle body cleaner (one that's safe for O2 sensor + cat converter) spray into the throttle body and scrub-clean it with a tooth brush.
Good luck,
JPN
hel2184
Dec 28, 2007 08:34 AM
skatermattc2
Jul 16, 2007 11:47 AM
HelgaTheS80
Mar 15, 2007 02:50 AM
Volvo70
Sep 13, 2006 05:37 AM
mp34
Apr 23, 2006 11:46 AM
