CBV Test
Hey,
My boost is only building around 5PSI. I upgraded the BCS to the ARD TCV and it did not fix it. My next idea is to test the CBV diaphragm. I have read about using a hand vacuum pump to test it. Can someone tell me what I should pump it up to and then what it should hold at? Thanks
If you read the thread I linked above, it should have links to videos etc., that showed what all I went through. Chances are, you have a tear in a turbo tube somewhere letting pressure escape. There is another high possibility that the ECU is dialing back the boost due to an error pending in the ECU.
