changeing 850 engine
Old Oct 9, 2007 | 10:57 AM
Alois123's Avatar
Default changeing 850 engine
I have 850 T5 2.0 Turbo 155 kw,but my engine is broken and i want to put 2.3 Turbo 166kw on my volvo.
Does anybody knowes is this possible.Someone thinks that the engine is the same but the electricity or ECU want match.
Old Oct 9, 2007 | 12:00 PM
robrike's Avatar
Default RE: changeing 850 engine
My guess would be that at a minimum you would need the ECU from the 2.3 along with the wiring harness. As for the mounts and all and if you will have to fabricate anything, I am not sure but someone else will be along soon who can tell you. Anything is possible but I am certain you would need the computer from the 2.3 engine otherwise the one from the broken 2.0 will be trying to send its fuel and ignition info and it will not match up which will mean no fire.
awwvolks
Dec 14, 2010 02:39 PM
boxpin
Oct 10, 2009 03:30 PM
bsamole
Apr 26, 2009 06:27 AM
dman777
Nov 16, 2007 09:41 AM
Yves666
Apr 5, 2007 06:31 PM
