changing power steering pump today!
Old Jan 11, 2009 | 12:20 PM
scubamike's Avatar
Default changing power steering pump today!
Hey guys can u tell me is there a speciality tool needed for belt tensionier I am replacing power steering pump thanks alot.
Old Jan 11, 2009 | 02:46 PM
JPN's Avatar
JPN
Default RE: changing power steering pump today!
To relax the tension on the serpentine belt tensioner, you would need a 1/2-to-3/4 adapter. However, the adapter would not fit perfectly and you would have to keep applying pressure to it while you turn the tensioner CCW, because the adapter would keep wanting to slip. I believe the dealer uses a special tool for this. If you can grind down the adapter for a perfect fitment, that would be ideal. For this type of tool modification, cheap tool is a great alternative. I would not do this on a Snap-on tool.
I believe Mathews Volvo Site had a pic of home-made adapter for this; I think someone welded aC25 coinonto an adapter.
JPN
Old Jan 11, 2009 | 09:27 PM
Psaboic's Avatar
I used the 1/2 inch drive to 3/4 inch drive adapter as tech mentioned and it wroked fine for me. I got it at Sears for about $15
Old Jan 11, 2009 | 09:39 PM
JPN's Avatar
JPN
I forgot to add one importance. The tensioner can be locked out at the max relaxed position to make the job a lot easier. There is a hole on the movable part of the tensioner, as well as on the backing plate. At the maxed out position, insert something like an Allen key or a drill bit so you do not have to abuse your arms[:@].
JPN
Old Jan 13, 2009 | 11:43 AM
wheelsup's Avatar
I used a nail puller/crowbar that fit diagonally in between, $4-$5 at Lowe's. I bought 4 of them to find one that fit and returned...all of them (don't tell them).
-matt
Old Jan 13, 2009 | 03:02 PM
bestharry's Avatar
I use adjustable wrench reaching from the bottom side (wheels turned all the way towards passenger side and removing one plastic nut to fold the liner inside) and there is a designed squared area at the end of the tensioner where it fits very securely. My guess is that 17mm or 19mm might do the same job but i never bothered to try it because my adjustable one fits quite comfy.
Old Jan 14, 2009 | 04:09 AM
arzy's Avatar
I used a chair leg and welded a piece of steel and ground it back to fit perfectly diagonally, chair leg gives great leverage.
Old Jan 14, 2009 | 07:07 AM
JPN's Avatar
JPN
You guys are so inspiring, makes me proud to be a member on this forum!!!
JPN
Old Jan 16, 2009 | 08:05 AM
Psaboic's Avatar
Geez, sounds like I took the easy way out by buying the tool!
MoneypitC70
Nov 22, 2009 05:50 PM
robnov
Apr 14, 2009 04:57 PM
elchingon2002
Mar 18, 2009 03:05 PM
aruizdelhoyo
Jan 22, 2009 04:46 PM
katiejoyful
Dec 12, 2007 04:49 PM
