Cleaning fuel injectors
Old Apr 10, 2009 | 05:24 PM
Saleen9090's Avatar
Default Cleaning fuel injectors
So once again my mind has changed and I will probably keep the car. Which means, I will buy the boost controller and crank the turbo to 13 PSI.
To make sure I'm getting fuel I was thinking about giving my fuel injectors a good cleaning. Anyone know a good way of doing so?
Also, If I do run lean, isn't there a "check engine" feature that will notify me before major engine damage?
~Thanks guys
Old Apr 10, 2009 | 10:07 PM
TIPSP's Avatar
Got Boost?
Not sure about the 850s if they warn you about lean.......
YOu can get a fuel cleaner and try that......Sea foam should be able to do the same thing
Me and my dad sent our injectors to Marren Fuel injection to be rebuilt and what not....
Wait for others to responed
Old Apr 11, 2009 | 07:59 PM
Saleen9090's Avatar
Would the boost from 8 PSI to 13 or 14PSI cause excessively more wear and tear on the head gasket? Car is old and I'm worried about a blown head gasket.
Old Apr 11, 2009 | 10:25 PM
TIPSP's Avatar
Got Boost?
I will not lie to you....I am not 100% sure.
It might It might not. Me and my dad fixed my Blown Head Gasket ~40,000 miles ago and I have been running 20,000miles on 12psi.... Car now has ~258,000miles and is strong....Just make sure you use 91+ octane and have go maintenance, which sounds like you have already done.
Old Apr 12, 2009 | 12:22 AM
Saleen9090's Avatar
Was it a pain replacing that blown head gasket? If not I may just buy one and do it to be safe. Do you know of a write-up on it?
Old Apr 12, 2009 | 12:14 PM
TIPSP's Avatar
Got Boost?
We fixed the 745...The 4 cylinder motors are pretty easy, just takes some time.
Not sure the difference between working on the 5 cylinder to the 4 cylinder....
Tech could probably tell what kind of job it is.
I don't know any writeups....
pinegrovedave
Apr 21, 2014 01:44 PM
Vmax
Apr 7, 2014 07:42 PM
shoeboxOH
2001-2013 model year V70
Oct 22, 2013 10:25 PM
chachouu
Dec 19, 2008 07:05 PM
WagHag
Apr 19, 2006 08:48 PM
