Code 435 and e-test failure
Old Jan 27, 2009 | 07:37 AM
bestharry's Avatar
Default Code 435 and e-test failure
I got the El light triggered on my 95 850 turbo y'day. As to what I understand is that this is the pre-cat O2 sensor going bad (maybe 2 days after a shot of SEA FOAM). I have few questions regarding this because this car failed the Ontario e-test last week and i got a temperory permit to drive it for 10 days only (2 more left).
1- Is the sensor same for turbo and non-torbo?
2- Is it possible to clean it - i mean will it work or help?
3- Can this really make the car fail in NO component of the emossions?
[IMG]local://upfiles/17470/504A8ED1D17E4DC7B7F9079A1719B1EB.jpg[/IMG]
[IMG]local://upfiles/17470/A653CF12A2514007AA2C77116A210780.jpg[/IMG]
Old Jan 27, 2009 | 10:44 AM
Default RE: Code 435 and e-test failure
If the O2 is bad you will need to replace it.It may have to much or to little gas going into the motor.
Old Jan 29, 2009 | 08:16 AM
bestharry's Avatar
Still failed the e-test with more bad results. Its failing only on NOx component of the test.
Does that mean that catalytic converter is shot or the tune-up, Oxygen sensor, turbo or anything like that plays a role in this?
Old Jan 29, 2009 | 08:19 AM
Still of the O2 is bad it can be messing it all up.
slowtype
Jan 29, 2012 04:14 PM
deniss
Feb 25, 2010 09:02 PM
ben watson
Jan 8, 2010 10:50 AM
ben watson
Dec 8, 2009 04:24 PM
willko1
Dec 13, 2005 01:38 AM
