Coolant advice
Old May 19, 2010 | 10:08 PM
IhateVampires's Avatar
Default Coolant advice
I had my 850 wagon in the shop a while back for brakes, and the mechanic said I had the wrong coolant in the car. He says it should be blue not green. Is there somewhere I can buy the blue coolant beside the dealer? I live almost 300 miles from the closest dealer.
Old May 19, 2010 | 10:32 PM
boxpin's Avatar
I recommend Mopar OEM coolant. Ya, Mopar.
Old May 20, 2010 | 12:00 AM
gdog's Avatar
Don't get excited; green will work just fine. Just change it out every 2-3 yrs or so...
Old May 20, 2010 | 06:59 AM
JimKW's Avatar
I use regular Prestone or Zerex whichever is the cheapest. I have used the NAPA brand also.
Old May 20, 2010 | 07:34 AM
B00$T CR33P's Avatar
Banned
In the summer I use distilled water and this
Old May 20, 2010 | 07:40 AM
Banned
"DEI Radiator Relief
Our first test additive, DEI's Radiator Relief mixed with distilled water, brought us down to a cool and much more manageable 183 F during low-rpm street driving. Under heavy load conditions we watched temperatures rise to about 205 F, but they stabilized - unlike our initial stock setup, which didn't seem to want to stop climbing. We also saw cylinder head temperatures drop here to 191 F - a good thing since our H22A4 has a knock sensor that was probably pulling timing out from knock due to excessive combustion chamber heat with the stock cooling mixture. We suspect a slight power increase here too. Radiator Relief performed best when mixed with water alone. Once antifreeze was added to the mix, temperatures rose by a factor of about two percent, but only when subjected to extreme load and rpm. So, unless you're interested in a race-only application, there's little to lose here from adding antifreeze to the mix."
From an article in TURBO MAGAZINE where they tested WATER-WETTER,HYPER-LUBE etc. and the DEI RAD. RELIEF made the biggest diff. in cooling
Old May 22, 2010 | 12:23 AM
gdog's Avatar
So what? The only criteria they measured was coolant temperature! Just run straight H20 if that's all you want.
Some of us live in areas where you have to be concerned with your coolant freezing or boiling in the summer; that's what anti-freeze is for.
Old May 22, 2010 | 08:11 AM
Banned
WOW !! What do you live in the north pole? There is nowhere in the cont. US where you would have to worry bout it freezing in the summer.
And running straight water is nowhere near as good as DEI RAD. RELIEF.
Did you not see where they said with stock coolant the temp.s kept climbing?
It will run about 50 degrees hotter moron.Thats why they make coolant additives such as DEI,WATER WETTER etc. genius.If you could run straight water and get the same results ppl. would do it.
But feel free to run straight water.Report back after your head gasket blows.
Old May 22, 2010 | 10:32 PM
I have always used anything. Sometimes straight water to top off. Never overheated any of my 7 Volvo's nor had any water pump failures, etc.
Old May 23, 2010 | 12:33 AM
Banned
Yea water to top off.Not straight water.
If just water worked so great then drag-racers etc would all do it but no it doesnt work great thats why companies have come out with additives to greatly reduce the temp.s
Did you not read the above posted article from TURBO MAGAZINE?
And thats just 1 of many articles from tuning/muscle car sources I have read on this subject.
no1pony
Sep 3, 2011 06:45 AM
aru5016
Jun 19, 2011 12:26 AM
cmayo313
Mar 18, 2011 12:09 PM
Ahmed
Aug 30, 2009 01:58 PM
timk
Nov 16, 2007 08:33 PM
