Coolant leak
Old Mar 8, 2007 | 03:12 PM
holdfast's Avatar
Default Coolant leak
Hey everyone,
I have a '95 850 turbo wagon. For a short while now I've seen some coolant leaking from the waterpump area, or thats where I assume it's coming from, I have not been able to get under the car to look. As it has been warmer here the last week or so, the leak has stopped completely. My best guess is that it only leaks when I use the heat or defroster. The passenger side of the windshield gets foggy on the inside, the drivers side does not. I plan to change out the water pump and all timing components this weekend. Any ideas? Any one experience this before?
thanks,
Mike
Old Mar 8, 2007 | 03:16 PM
s80t6schcik's Avatar
Default RE: Coolant leak
do you know about how much is leaking and when running or sitting does the defroster smell musty?/moldy?
Old Mar 8, 2007 | 03:23 PM
holdfast's Avatar
It leaks anywhere from a 4 inch puddle to a larger stream on the ground when sitting. I have not checked while running. The cabin smells like coolant when the engine gets to operating temp with the defrost running.
I have done no other work on the car recently.
Old Mar 8, 2007 | 03:39 PM
check heater core connections and anycoolant in car around floorboard to locate leak easy get a buddy put in "n" have buddy rev to 4-5k rpm and watch for running water...also get some uv dye and a black light works really well
Old Mar 8, 2007 | 09:23 PM
If the heater core is draining out the drain it will drop from the middle of the car under where the cat. converter is.
Old Mar 9, 2007 | 03:24 PM
Psaboic's Avatar
I agree, it sounds like you have a leak in the heater core. One other area to check is the where the heater hoses go from the engine into the heater core (through the firewall). You might have leaky O-rings there.
Old Mar 10, 2007 | 03:30 PM
holdfast's Avatar
thanks guys, im pulling it apart and further investigating everything today...
no1pony
Sep 3, 2011 06:45 AM
aru5016
Jun 19, 2011 12:26 AM
cmayo313
Mar 18, 2011 12:09 PM
Ahmed
Aug 30, 2009 01:58 PM
timk
Nov 16, 2007 08:33 PM
