Coolant leak
Old Jul 17, 2008 | 05:44 PM
RalphieAle's Avatar
Default Coolant leak
I noticed that is small amount of coolant dripped out in front of the front wheel. What kind of problem am I looking at??
Old Jul 17, 2008 | 06:23 PM
Default RE: Coolant leak
Could be many things best to have it pressure tested and inspected.
Old Jul 17, 2008 | 09:33 PM
BriGuy's Avatar
Which side is it dripping on? Mine just started dripping on the passenger side because the expansion tank is leaking somehow. This weeks project is to replace the expansion tank.
Old Jul 18, 2008 | 03:25 PM
catalistt's Avatar
if you have a/c it could also be water vapour from the exapansion chamber mine drips out just in front of the wheel i also thought it was a pipe or the tank turned out it was the a/c
Old Jul 21, 2008 | 08:47 AM
Psaboic's Avatar
If you are SURE it is coolant, thencheck all the hose clamps. If they are good, thenget the system pressure tested. Otherwise, as earlier posted, it could simply be condensatiuon fron the A/C.
no1pony
Sep 3, 2011 06:45 AM
aru5016
Jun 19, 2011 12:26 AM
cmayo313
Mar 18, 2011 12:09 PM
Ahmed
Aug 30, 2009 01:58 PM
timk
Nov 16, 2007 08:33 PM
