Coolant light
Old Jan 31, 2010 | 03:48 PM
Riculus's Avatar
Angry Coolant light
Hi Guys,
I have a little problem. On Friday night on my way home my coolant light came on. It was coming on anoff/ on and off. My brother used the car on Saturday and he put coolant in it. He over filled it. I took the out today and and the light came on again. I had no choice but ti drive around 2 miles with it(checked to see if the level is low and thats when I found out it was over filled). I noticed that when i'm on flats and hills the light comes on and donwslope it goes off. When I got home I removed some of the coolant to get it to the capacity level.
Could it be my coolant sensor is bad
Any help will be apprecciated
Riculus
p.s. I have a 1995 850 glt non-turbo
Old Jan 31, 2010 | 04:42 PM
have you driven it since you removed some of the coolant?
Old Jan 31, 2010 | 08:11 PM
Riculus's Avatar
Took it on a 5 mile ride tonite and the light did not come on. The big test will be tonite when I go to work. Its 30 mile round trip. I'll fill you guys in tomorrow.
Old Feb 1, 2010 | 08:46 AM
Psaboic's Avatar
Crazy as it sounds, you might have had an air bubble in the system. Other than that, I can think of no reason the light would come on if it is overfilled, unless the coolant level sensor is gone....
Old Feb 1, 2010 | 09:49 AM
boxpin's Avatar
If you have fluid in the reservor(sp) and its full and the light is coming on then your sensor is going or gone. The sensor is in the bottom of the reservor and would not come on unless the coolant level is low within the reservor.
Old Feb 1, 2010 | 03:58 PM
Riculus's Avatar
Thanks for the feedback guys. I drove to work last night and back home and it did not come on. If it does again I would replace the sensor.
Riculus
no1pony
Sep 3, 2011 06:45 AM
aru5016
Jun 19, 2011 12:26 AM
cmayo313
Mar 18, 2011 12:09 PM
Ahmed
Aug 30, 2009 01:58 PM
timk
Nov 16, 2007 08:33 PM
