Coolant Pipe Replacement Nightmare
Old Aug 11, 2009 | 03:09 PM
frustrator-bolt's Avatar
Cool Coolant Pipe Replacement Nightmare
I had a hairline crack in my coolant pipe and bought original volvo dealer replacemnt part. I see where the one end goes into the engine block and it looks like I have to remove the timing cover & possibly the cylinder head to get at that end. Since the leak is on the driver side end I am thinking of just cutting the replacement pipe in half and using hose / hose clamps as a simple fix. If anyone has replaced their 850 turbo coolant pipe I sure would appreciate their guidance.
Old Aug 11, 2009 | 07:00 PM
silkhope's Avatar
Hey I just took mine of my 94 turbo, but my engine is out of the car! It was a bit of a pain but not to bad. One big obstacle for you will be the bolt on a support strap that attaches under the exhaust manifold. If you can get that out then start removing the other clamps and bolts. I was able to wiggle and pull my pipe out of the O-ring in the back of the water pump. I would not do anything until you find a way to get the support hanger loose. As for doing the cut and splice you had what for someone who has done it. I have a photo of it but can not get it to upload.
Old Aug 11, 2009 | 07:42 PM
silkhope's Avatar
Got the photo you can see the support strap that would be under the exhaust manifold, and behind the turbo.
Old Aug 12, 2009 | 10:36 AM
OK - Thanks I was able to get the exhaust manifold off and get at that bolt to remove the pipe.
Old Aug 12, 2009 | 09:21 PM
redbottle's Avatar
I use a long 10mm socket with an extension that will extend your rachet or wrench close to the heat shield.
ToOldForDis1954
Feb 13, 2011 01:41 PM
itr
Feb 2, 2011 07:48 PM
dbarstow
Aug 1, 2010 02:06 PM
m2point1
May 30, 2008 06:02 PM
funnyguy44444
Jun 23, 2007 04:36 PM
