CV joint
Old Oct 31, 2009 | 05:47 PM
rover4x4's Avatar
Default CV joint
Can anyone offer any insight in to CV joint replacement on a 96 850 non turbo with an autobox.
Old Nov 1, 2009 | 07:53 PM
garypettengill's Avatar
Loosen the axle nuts with the car on the ground. Put the car on jack stands. You have to pull the lower ball joints out of the spindle, then the axle ends will come out of the spindles. Once they are out of the spindles a large screwdriver/pry bar pops the axles out of the transmission. Oh, on the right side you need to remove the axle bearing retainer from the engine. It is actually explained real well in my Haynes manual, with pics.
dpvovo
Feb 18, 2019 07:41 PM
tepuy
Sep 7, 2005 08:54 PM
jcmartin
Jun 25, 2005 11:49 AM
floryed
Apr 10, 2005 12:23 PM
indagutter
Oct 11, 2004 07:10 PM
