dash- light out indicatior
Old May 13, 2008 | 08:49 AM
je850's Avatar
Default dash- light out indicatior
Light out indicatior goes on when I put on the brakes. This comes and goes I have only had car for a few days. Did replace the bulbes for the bracks and the lights work 1997 850 t-5 with 90,000
Thanks
Old May 13, 2008 | 09:31 AM
JPN's Avatar
JPN
Default RE: dash- light out indicatior
Did you also check the high-mount lights? On spoilered models, even one bulb out can trigger that light. On non-spoilered models, see if the high-mount lamp is still lighting.
JPN
Old May 13, 2008 | 11:49 AM
je850's Avatar
It is a sedan and I just checked the third light and it works.
Old May 13, 2008 | 12:08 PM
gullyg's Avatar
This has just happened to me as well.
When I touch the brakes the light-out warning comes on - a quick tap on the top light (T5 with no spoiler) behind the rear glass confirms it's a dodgy connection.
Try tapping the lights to see if it's intermittant.
Old May 13, 2008 | 12:30 PM
je850's Avatar
That might be it as i did check the light and then the dash lite was off I will try dan do it when the dash light is on agan Thanks
Old May 14, 2008 | 08:33 AM
Psaboic's Avatar
When I recently had this same issue, I swapped the right and left bbrake bulbs and no more issue. Your problem is probably a loose/dirty connection
Glenn
Old May 15, 2008 | 10:37 AM
je850's Avatar
Thanks for the help I unpluged all connections in the third light and it has worked for two days hope that was it a bad connection
Thanks
Old May 16, 2008 | 08:53 AM
Psaboic's Avatar
Clean the connectors and plug them back in and see what happens. If all the lights in the third brake light work and you still get a bulb out light, I would look for frayed/pinched wires in the third brake light harness
trs80
Jun 25, 2011 02:05 PM
ramayr98
Apr 12, 2010 02:19 AM
tr_car_nut
Oct 2, 2008 07:52 PM
tr_car_nut
Jan 19, 2008 09:37 AM
