DASH REPLACEMENT
Old Apr 23, 2008 | 10:52 PM
ROBLU540's Avatar
Default DASH REPLACEMENT
I would like to replace my dash, since it is all cracked and warped. I bought another dash but am worried about the airbags. Am i going to run into any problems? can i disconnect the battery and then disconnect the airbags without having a problem with the computer? any suggestions.
Thanks Rob
Old Apr 24, 2008 | 06:55 AM
JimKW's Avatar
Default RE: DASH REPLACEMENT
If you are just doing the dash pad there are instructions pinned to the top of this forum.
Old Apr 24, 2008 | 10:40 AM
Maxbaby's Avatar
You should have no problems if you disconnect the battery about an hour before you start mucking around the airbags.
Old Apr 25, 2008 | 06:27 PM
If the battery is disconnected you will be fine.
Old Apr 26, 2008 | 07:42 PM
ROBLU540's Avatar
Replaced it last night no problems. thanks
Old Apr 26, 2008 | 09:07 PM
Glad it all went smooth.
Did you use my post to remove it?
Old Apr 27, 2008 | 03:22 PM
ROBLU540's Avatar
Yes,plus i have vadis, I was worried because i had to pay $110 for dealer to reset the abs warning message on my 04 v70 after a ipod adapter install.
Old Apr 27, 2008 | 09:39 PM
OK glad the post is helping people.
trs80
Jun 25, 2011 02:05 PM
tr_car_nut
Jan 19, 2008 09:37 AM
guptash
Dec 24, 2006 11:21 AM
bykrmom
Jul 26, 2005 09:40 AM
