Dashboard lights coming on when car is off
Old Dec 15, 2017 | 04:03 AM
Radfordalum's Avatar
Default Dashboard lights coming on when car is off
I've changed the ignition switch (with a used one) and the issue still persists. Is there any particular relay that could be faulty? I'm confused
Old Jan 14, 2018 | 01:36 PM
volvowiringdiagrams.com and volvotips.com will help
Old Jan 23, 2018 | 12:35 PM
boxpin's Avatar
That sounds more like your headlight switch being the issue. When it does it unplug the dimmer and see if they turn off.
Old Jan 29, 2018 | 09:03 AM
I have unplugged both the headlight switch as well as the dimmer switch and the lights remain on. I then changed both switches and repeated unplugging them and the issue remains. I however noticed that a wire was cut. I don't know if this could be a contributing factor. I have really been using the Volvo as I purchased a BMW X3 18 months ago. Just prior to the BMW purchase I had the dashboard changed and I believe this issue stems from the donor dashboard
Old Feb 3, 2018 | 09:20 PM
Ouch! They should have kept your harness.
Radfordalum
Dec 16, 2017 09:38 AM
mountain lion
Apr 26, 2011 03:37 PM
mcaanda
Apr 27, 2010 01:00 PM
chrystald423
Mar 27, 2010 08:05 AM
QuentinOK
Feb 4, 2010 12:18 AM
