deleting the wastegate solenoid
Old Feb 24, 2016 | 08:35 PM
jdiding's Avatar
Default deleting the wastegate solenoid
if i just wanted to up the boost a little bit to around 12 or 13 psi below the boost cut could i eliminate the solenoid and use a manual or electronic boost controller ? or even a higher psi wastegate actuator ? or would the ecu get angry and pull power and timing ?
Old Feb 25, 2016 | 07:56 AM
tryingbe's Avatar
Or engine gets mad and bend the connection rods.
Old Feb 28, 2016 | 04:00 AM
jdiding's Avatar
i was planning on leaving it plugged in just removing the vac lines from it so it don`t throw a code
Old Feb 29, 2016 | 10:58 AM
claymore's Avatar
Yep, it will work just fine, you won't bend rods at this sort of level.
Old Mar 1, 2016 | 04:46 PM
boxpin's Avatar
Yes, this is totally fine and if you some day get a tune you can set the boost beyond the fuel cut off area. Enjoy.
ENDEE666
Jan 29, 2024 01:33 PM
anxious
Feb 28, 2009 07:01 AM
BigAl
Jul 22, 2008 06:21 PM
chance011
Aug 31, 2007 03:15 PM
tcrossley
May 20, 2006 12:50 AM
