Drivers seat adjustment...?
Old Jan 21, 2011 | 07:00 AM
North42g's Avatar
Default Drivers seat adjustment...?
1995 Volvo 850 GLT:
Drivers electric seat isn't working properly.
It will move front to back & back to front.
It will also tilt as designed. But that moves the whole entire seat position.
It will NOT allow me to adjust the "seat back" up or down. The only way to
get comfortably upright is to adjust the "tilt" function.
I need it to be able to adjust the "seat back."
How does it work? is it cable driven? I can hear a motor running when the the switch is activated. However there is no "seat back" movement.
Is there a procedure to open up the seat so that I may have a look inside to determine what is malfunctioning?
It is very uncomfortable to drive. I bought it in October with 150, 000 miles on it. In wonderful shape. Yeah,...it needed some maintenance & some fixing, but aside from the Rear Shocks and Brakes all around, it got a Blower Motor & Resistor. Flushed the Antifreeze/Coolant, Flushed the Transmission, gave it a new Timing Belt & Tensioner & some Winter Tires and the Wife has been enjoying it ever since.
I paid only $100. for the car. [Yeah, I'm bragging..a little.]
A since I'm am Auto technician at a private shop , I was able to acquire parts for a relatively decent cost.
-No matter what though...the Mrs. won't be happy until that darn seat issue can be repaired!
Soooo.... if anyone ...I mean anyone...has an idea on how to fix/repair the "seat back" adjuster on my favorite car....please feel free to relinquish your ideas/knowledge so that i can live happily ever after!!!
Thank You.
North42g
Old Jan 21, 2011 | 11:33 AM
vtech's Avatar
Originally Posted by north42g
1995 volvo 850 glt:
It will not allow me to adjust the "seat back" up or down. The only way to
how does it work? Is it cable driven? I can hear a motor running when the the switch is activated. However there is no "seat back" movement.
Is there a procedure to open up the seat so that i may have a look inside to determine what is malfunctioning?
It is very uncomfortable to drive. I bought it in october with 150, 000 miles on it. In wonderful shape. Yeah,...it needed some maintenance & some fixing, but aside from the rear shocks and brakes all around, it got a blower motor & resistor. Flushed the antifreeze/coolant, flushed the transmission, gave it a new timing belt & tensioner & some winter tires and the wife has been enjoying it ever since.
I paid only $100. For the car. [yeah, i'm bragging..a little.]
a since i'm am auto technician at a private shop , i was able to acquire parts for a relatively decent cost.
-no matter what though...the mrs. Won't be happy until that darn seat issue can be repaired!
Soooo.... If anyone ...i mean anyone...has an idea on how to fix/repair the "seat back" adjuster on my favorite car....please feel free to relinquish your ideas/knowledge so that i can live happily ever after!!!
Thank you.
North42g
yes , all of the seat functions have a motor and cables , the back uses one cable . Try a google search on this problem . It's been years since i did one . I remember removing the upholstery . Best to get a new cable although many have used a shortening method , but why bother for such a small savings when you might have to do the job twice . Sometimes it is necessary to recalibrate the seat when done with a repair . It's easy with the volvo scan tool but can be done with a push button method at the diagnotic plug b6 - a real pain . Vtech
Old Jan 21, 2011 | 11:48 AM
boxpin's Avatar
I have done the cable shortening method and it has worked great every since. I did it without removing the seat from the car but it was tough. I didnt heat them up, I took the cable out and cut a bit out of it.
Old Jan 21, 2011 | 11:34 PM
15. 850 Seat back cable repair
https://volvoforums.com/m_88154/tm.htm
washout
Aug 3, 2013 07:45 PM
nextproject
Nov 16, 2009 07:04 PM
Georgia Boy
Jul 9, 2008 01:16 PM
dpallen
Apr 2, 2008 07:09 PM
clhhunter
Mar 2, 2006 08:48 PM
