Ecc
Old Jan 29, 2014 | 10:53 AM
Zelenay85's Avatar
Default Ecc
I have a 1995 85o turbo auto with 152000 miles and I have the same problem with codes from b1 122 124 126 132 134 151 211what wood all that be a bad ground or a bad senser ? When I do test it will not test the speedomider and the car did sit for some time as well as the cooling fan never seem to come on by my temp never gos over 3 o'clock on gauge I have replaced and tested relays what else could it be?
Old Jan 29, 2014 | 11:16 AM
Have you reset the codes and see what came back?
Old Jan 29, 2014 | 12:10 PM
Zelenay85's Avatar
Yes they do
Old Jan 29, 2014 | 03:09 PM
boxpin's Avatar
Connect an OBDII to it and see if you get a clearer answer. There is probably just one main issue here and the rest are children.
Old Jan 29, 2014 | 08:31 PM
Have you looked the codes up on Matt's site?
Old Jan 29, 2014 | 08:34 PM
http://www.matthewsvolvosite.com/read-codes-volvo-850
Old Jan 29, 2014 | 09:05 PM
OBDII port on a 1995 Above and a little to the left of the shifter.
Badvibes
Sep 26, 2011 06:15 PM
manyvolvos
Jan 23, 2006 06:10 PM
woodworker
Aug 24, 2005 09:06 PM
dave_n_s
May 17, 2005 11:06 PM
kicmx5
Jan 31, 2005 02:47 PM
