Ecc damper pull?
Old May 8, 2021 | 12:46 PM
rcvolvo's Avatar
Default Ecc damper pull?
96-850- codes -222 pass. side damper motor position sensor shorted to earth. 322-pass. side damper motor active too long.--211 dr. side damper motor position sensor open circuit or shorted to 12 volts.--325-recir. damper motor active too long.-231-ventil. damper motor position sensor open circuit or shorted to 12 volts. After researching it would seem that I will be pulling at least two damper motors maybe 3. It looks like they can be cleaned and or the actuating shafts need to be reconnected or repaired. Anyone have any advice or experience on doing this? Blowing hot air out dr. side along with getting the flashing lights on ECC fixed.
wolfchoir
Jul 29, 2014 02:30 PM
mcarbaugh
Apr 2, 2011 01:23 PM
matthew.lemke@gmail.com
Dec 19, 2010 01:21 AM
cava
Aug 30, 2006 04:53 PM
