EGR again
Old Feb 9, 2006 | 12:57 AM
sithhound's Avatar
Default EGR again
Hey everybody. I have a new problem. To start out my 1994 850 check engine light was on. It gave me a 2-4-1 EGR malfunction. From this forum I discovered that that usually means the EGR is dirty. OK, I took it apart, and cleaned it (it was totally clogged.) Reset the light, and it stayed off for about 60-70 miles. Today it popped back on, and now it gives me a 1-5-4 (EGR system-leakage or excessive flow). How bad is this? Do I need to fix it? If so anyone have any hints as to what I should do? I couldn't find anything useful either on here or on Yahoo.
Thanks in advance for any tips.
Old Feb 11, 2006 | 05:24 PM
Default RE: EGR again
Did you use a new gasket on the valve?
Did you get the nut on the metal pipe tightened all the way?
Old Feb 11, 2006 | 10:40 PM
sithhound's Avatar
As far as I know. I paid for a new gasket. I ran into trouble (the bolts holding the EGR to the intake manifold both snapped. I tried removing it, but it got too complicated), so I had it towed into the shop. Think I should have them look at it again, or just ignore it. The city I live in is not large enough to have to pass an emissions test, and it does not smell bad.
Thanks.
Glad to see you are back, Tech.
Jay
Old Feb 11, 2006 | 10:48 PM
I would take it back to them and have them look at it. They finished the job.
Glad to be back.
91shelby
Apr 29, 2011 01:04 PM
VTBricked
Dec 30, 2009 09:11 PM
Erich73
May 19, 2009 11:40 PM
burnferris
Feb 8, 2009 04:43 PM
dimito
Mar 27, 2008 07:27 PM
