Electrical draw I can't seem to find?
I'm assuming this darw is killing the battery over time. One way to check is to pull the fuse for the accessories one at a time (radio, blower motor, etc) and she if that stops the draw. At the least, it is a place to start. IF not, you are going to have to start checking for voltage drops with a voltmeter
Once again I side with Tech. Voltage drop will only indicate a resistance.An inductive amp meter/probe will indicate draw, witch is what you are looking for. How long does it take to no-start? I may be wrong but 3-7 milliamps is normal. If you are higher, say in the 23 milliamp area, you have a problem.
thegazelle
07-08-2014 09:44 PM
crazypenguins
07-10-2012 12:52 PM
Brennan.Messick
09-19-2011 03:06 PM
defuse
07-18-2005 10:34 PM
