Electrical Timing
Old Jul 29, 2006 | 04:20 PM
defiant187's Avatar
Default Electrical Timing
I replaced my head gasket on my 94 850 turbo and went to start my car and it ran very slugish then staled with some backfireing. Thought my timing was off so I retimed the valves and still the same problem. Next we put a timing light on the engine and the electrical timing is advanced, so I changed the position on the R.P.M sensor but then the car would not start at all so I positioned it back to original. Any more thoughts on how I can fix this problem or proberly time my electrical? Ps tried pulling codes but the damn L.E.D light is broken. no clue on Ecu and fuel ignition management systems?
Old Jul 29, 2006 | 04:45 PM
info2x's Avatar
Default RE: Electrical Timing
Not sure what your problem is, and I'm not even going to venture a guess. If one of the more experienced members doesn't come up with something the dealer should be able to pull the codes from the system because if I remember correctly they have a scanner so they don't have to use the LED.
Old Jul 29, 2006 | 09:22 PM
Remove the Dist Cap and rotor and inspect the rear cam and Cup that holds the rotor. It only goes on one way but can also go the other way and be off.
7zarc7
Mar 24, 2010 07:17 AM
04v70
Jul 17, 2009 11:01 AM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
