Engine pic of a 1996 850 non-turb0
Old Mar 2, 2011 | 03:13 PM
ajene's Avatar
Default Engine pic of a 1996 850 non-turb0
I have a 850 and changed the flame box but still not good and the person I brought the car from worked on it to so vacuum hoses maybe out of place but their is not any pictures of plain 850's all the tutorial's shoe turbo's so can someone post a non-turbo 850 engine picture. Thanks.
Old Mar 2, 2011 | 05:13 PM
ibified's Avatar
you should have a vacuum diagram on the cover for the throttle cable.
Can you specify a little more when you say "still not good"? because I'm not sure what your specific issue is. If you're still smoking, it's not gonna be vacuum lines out of place that cause it.
Old Mar 2, 2011 | 06:36 PM
Mad Matt's Avatar
Or on the under side of the hood. That's where I have the routing on my cars.
I would think the routing should be very similar as the '93 MY minus the EGR since it's pretty much the same engine.
Old Mar 2, 2011 | 08:22 PM
ajene's Avatar
Default Still smoking
Yes it still smokes a bit but I was just trying to make sure the vaccum hoses were right because it's still misfiring and rough idle but once the rpm's are adove 3,000 it sounds like a champ.
Old Mar 2, 2011 | 08:47 PM
The car should not misfire at any rpm. You can't drive around over 3,000 rpm's. Matter of fact, I almost never see 3,000 rpms.
Have you done a stage 0? How old are the spark plugs and wires?
Old Mar 3, 2011 | 09:05 AM
ajene's Avatar
New plugs and wires. What's a stage 0?
Old Mar 3, 2011 | 09:34 AM
Mad Matt's Avatar
Full stage 0 list:
Plugs
cap/rotor
oil/transflush
filter (oil)
hoses (the little vac lines)
samco hose kit
02 sensors
fuel pumps
clean injectors
clean IC/IC plumbing
Air filter
plug wires
Great thread to read...
http://volvospeed.com/vs_forum/topic...-searchhow-to/
gilber33
Dec 22, 2011 10:14 AM
chef
Jan 25, 2009 01:04 PM
chef
Oct 9, 2008 03:19 PM
rfa1972
Apr 19, 2007 03:36 AM
KINGI5T850
May 8, 2006 01:38 AM
