Engine Removal Question
Old Nov 30, 2016 | 10:59 AM
amazon2's Avatar
Default Engine Removal Question
When removing 850 engine can the hub/axle/strut assembly be swung outward far enough to slide inner axle spline out of transaxle? I'd rather not remove the outer axle nut if possible. TD
Old Nov 30, 2016 | 11:21 AM
ES6T's Avatar
I doubt it but I've never tried it. I'd rather just remove the nut.
You could also disconnect the ball joint and strut and remove the caliper and remove the whole spindle with the axle attached.
Old Nov 30, 2016 | 01:21 PM
amazon2's Avatar
Thanks for the suggestion of removing the spindle & axle together. Car is in a situation where air tools are not available for getting the spindle nut loose. TD
Old Nov 30, 2016 | 01:22 PM
ES6T's Avatar
Ah okay. Without airtools, you'd probably be best to pull the whole spindle. Good luck.
Old Nov 30, 2016 | 05:49 PM
firebirdparts's Avatar
I've never understood the fascination with not applying torque yourself. You can easily remove that with a breaker bar. When I say easily I mean in about 1/50th of the time it'll take you to get the strut bolts out without air tools.
Old Dec 15, 2016 | 08:20 AM
mikwik's Avatar
Can you give us an update. I'm especialy curious about the L/axle with the cir-clip. I have removed lots of axle nuts without air tools. Saves a ton of work/time getting axles out (and engines/trannys). Hope all went well.
Braaad
Aug 27, 2016 05:13 PM
Grey Bearded One
2001-2013 model year V70
Oct 13, 2013 11:20 PM
johnwartr
Apr 12, 2013 02:48 PM
HelgaTheS80
Jan 6, 2007 11:48 AM
JPN
Sep 10, 2006 03:05 AM
