Engine stops while driving
Old Feb 25, 2006 | 10:28 AM
bayernfanatiker's Avatar
Default Engine stops while driving
Hello everyone,
Hope somebody can give me an idea what is going on with my 94 Volvo 850. Driving down the road, the engine quits, but it's easy to get started again. I thought maybe it could be the fuel pump, but then wouldn't it just not work period. Let me know what you think.
Mike-
Old Feb 25, 2006 | 12:40 PM
info2x's Avatar
Default RE: Engine stops while driving
have you replaced the fuel filter? If its getting clogged it may prevent enough gas from getting to the injectors. The fuel pump relay may also be suspect as well as the wiring to the pump. Does it seem to happen randomly or is it after you hit a bump or something?
Old Feb 25, 2006 | 06:49 PM
It could also be a bad Cam sensor. Also make sure all the wires at the positive terminal are clean and tight.
krt919
Nov 29, 2014 03:50 PM
cb1313
Feb 21, 2014 06:26 PM
USFBull56
Oct 2, 2013 02:36 AM
NickF
Aug 15, 2012 09:04 AM
Daffydavid
Mar 26, 2007 05:28 AM
